[GRASS-dev] Re: [GRASS GIS] #1158: g.mremove fails when used with
wildcard in WinGRASS-6.4.0-1
trac at osgeo.org
Sun Sep 26 17:07:23 EDT 2010
#1158: g.mremove fails when used with wildcard in WinGRASS-6.4.0-1
Reporter: lponti | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.1
Component: Vector | Version: 6.4.0
Keywords: g.mremove, wildcards | Platform: MSWindows 7
Cpu: x86-32 |
Comment(by lponti):
Replying to [comment:6 hamish]:
> are wildcards from `g.mlist` working?
Using self built (noticed that http://josef.fsv.cvut.cz/wingrass/ has not
been updated in the last few days) releasebranch_6_4 revision: 43598. In
North Carolina location, mapset user1:
GRASS 6.4> g.mlist type=vect pattern="bus*"
busroute1
busroute11
busroute6
busroute_a
busroutesall
busstopsall
> how about `g.remove vect=` for a single vector map?
It works:
GRASS 6.4> g.copy vect=busroute1,routebus1
Copy vector <busroute1 at PERMANENT> to current mapset as <routebus1>
GRASS 6.4> g.remove vect=routebus1
Removing vector <routebus1>
It works with g.mremove -f with wildcard too:
GRASS 6.4> g.mremove -f vect=route*
Has it been changed since 6.4.0-1? I assumed nothing had changed since the
ticket was unmodified. Last report was from Helmut who confirmed about
nine days ago in winGRASS 7.
Thanks,
Luigi
Ticket URL: <http://trac.osgeo.org/grass/ticket/1158#comment:7>
