[GRASS-dev] vdigit
Mohammed Rashad mohammedrashadkm at gmail.com
Wed Sep 29 07:26:25 EDT 2010
Ok. but want to create a new vector map with some points/lines drawn on it.
I dont need the digitizer features for that. the code to put some point on
the shape files is coded inside the source. Is this possible. If yes how?
and thanks for previous post:)
On Wed, Sep 29, 2010 at 3:54 PM, Martin Landa <landa.martin at gmail.com>wrote:
> Hi,
> 2010/9/29 Mohammed Rashad <mohammedrashadkm at gmail.com>:
> > How can I use vdigit module(C version) for my custom application built in
> > top of GRASS?
> > How to link the vdigit library and use its functions?
> there is no 'vdigit' library. C module v.digit implements it's own
> functions using vector library. Anyway wxGUI digitizer and v.edit uses
> vedit library [1] which has been designed for this purpose.
> Martin
> [1] http://grass.osgeo.org/programming6/Vedit_Library.html
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Rashad
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20100929/cab75818/attachment.html
