[GRASS-dev] wxvdigit
Benjamin Ducke
benjamin.ducke at oxfordarch.co.uk
Wed Sep 29 09:03:15 EDT 2010
Generally, you can use C libraries from C++:
http://www.parashift.com/c++-faq-lite/mixing-c-and-cpp.html
Then look here, and read the sections on the GRASS
vector architecture and the VEdit library:
http://grass.osgeo.org/programming6/
You will find there is quite a lot of functionality in there
already.
The rest is up to your creativity.
Ben
----- Original Message -----
> thank you. will you please elobarate. I dont mean to send the source
> code. just add more details.
> On Wed, Sep 29, 2010 at 6:03 PM, Benjamin Ducke <
> benjamin.ducke at oxfordarch.co.uk > wrote:
> Why don't you just call the C API from C++?
> The VEdit C library has some convenient functions for building
> a digitizer application.
> Ben
> > What I want is a vector digitizer using GRASS. I read programmers
> > manual and saw the code to create vector files. I want to edit/add
> > data(points/lines or atleast points) on the new created vector map
> > like the wx digitizer. I am using C++ for developing my application
> > not python or wx.python.
> > I knew how to replace python code with my C++. But wx digitzer uses
> > a swig interface and calls a .so file _grass6_wxvdigit.so located in
> > /usr/local/grass-6.5.svn/etc/wxpython/vdigit.
> > Can I use the .so file said above in my code. As I am developing
> > with C++ I can directly link the
> > _grass6_wxvdigit.so file. I am asking that Can I link the .so file
> > with my C++ code . normally its possible and easy. But the .so files
> > is swig generated(I maybe wrong)
> > Is Information said above is enough or If you want more please tell
> > me which part need more explanation. I am ready to provide you.
> > On Wed, Sep 29, 2010 at 5:49 PM, Benjamin Ducke <
> > How about you explain to us what you want to achieve with your
> > program? If people here understand what you are trying to do,
> > they can give you more useful advise.
> > If all you want is to create some vector objects, you can use
> > the GRASS C API from within your C++ code. There is a programmer's
> > manual which you can consult:
> > http://grass.fbk.eu/devel/index.php#prog
> > and of course, you have the source code of all GRASS GIS modules,
> > so you can try to find one that does something similar to what
> > you want and learn from that.
> > Ben
> > > How can I communicate with wx digitizer ( i mean using the
> > > wxdigit.so file) using a c++ program.
> > > All I need is create an map with one point from a c++ program
> > > which is linked to _grass6_wxvdigit.so located in
> > > How to access the functions of the library using a C++ program run
> > > from grass shell with all variables set. My program renders a map
> > > when run from grass shell. Now I want to add
> > > digitzer;
> > > -- Rashad
> > > _______________________________________________ grass-dev mailing
> > > list grass-dev at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/grass-dev
> > ------ Files attached to this email may be in ISO 26300 format
> > (OASIS Open Document Format). If you have difficulty opening them,
> > please visit http://iso26300.info for more information.
> > -- Rashad
> ------ Files attached to this email may be in ISO 26300 format (OASIS
> Open Document Format). If you have difficulty opening them, please
> grass-dev mailing list
> -- Rashad
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
