[GRASS-dev] error while comipiling GRASS SOURCE CODE IN Msys
sunil
sunilrajkiran at gmail.com
Thu Sep 30 01:31:48 EDT 2010
I'm setting up an environment on Windows using MSYS, im following the
material BUILD FROM SOURCE from the website
http://www.webalice.it/marco.pasetti/qgis+grass/BuildFromSource.html
1) while giving "make" to the grass-6.3.0 ,i have got errors like
make[2]: *** No rule to make target
`/usr/local/src/grass-6.3.0/dist.i686-pc-mingw32/lib/libgrass_vect.dll',
needed by `
/usr/local/src/grass-6.3.0/dist.i686-pc-mingw32/bin/v.parallel.exe'. Stop.
plz reply me , , if this is an error ,,
View this message in context: http://osgeo-org.1803224.n2.nabble.com/error-while-comipiling-GRASS-SOURCE-CODE-IN-Msys-tp5586640p5586640.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
