[GRASS-dev] after compiling GRASS ,
Benjamin Ducke
benjamin.ducke at oxfordarch.co.uk
Thu Sep 30 03:24:11 EDT 2010
But if people don't even have the time to spell out "you",
then how do we expect them to find the resources it takes
to read a whole message on screen?
Please: if something goes wrong then sit back for at least
10 secs, maybe have a tea, look at it again, make sure you
tried your best to fix it.
THEN write to this list.
This is software development, not Twitter.
Best,
Ben
----- Original Message -----
> sunil wrote:
> > the following compilation log came , , can u explain
> > what should i do next
> > GRASS GIS compilation log
> > ------------------------- Started compilation: Wed Sep 29 11:21:01
> > IST 2010
> > Errors in:
> > /usr/local/src/grass-6.4.0/lib/gis
> here you go:
> > In case of errors please change into the directory with error and
> > run 'make'.
> > If you get multiple errors, you need to deal with them in the order
> > they appear in the error log. If you get an error building a
> > library, you will
> > also get errors from anything which uses the library.
> > -- Finished compilation: Wed Sep 29 11:47:57 IST 2010
> for WinGrass see also
> https://trac.osgeo.org/grass/wiki/CompileOnWindows
> Hamish
> _______________________________________________ grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
