[GRASS-dev] [GRASS GIS] #1184: "d.vect display=attr" imply grass open process but doesn't close them.
GRASS GIS trac at osgeo.org
Thu Sep 30 04:31:37 EDT 2010
 Reporter:  met           |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  blocker       |   Milestone:  6.4.1
Component:  Display       |     Version:  6.4.0
 Keywords:  display=attr  |    Platform:  MSWindows XP
      Cpu:  Unspecified   |
 Using version 6.4.0 or 6.4.0 RC7 the defect shows up, instead of RC6
 in which not, operative system Windows XP professional.
 When you are using a PAN or ZOOM command, or simply adding a layers,
 (looking from windows taskmanager)map display start a "cmd.exe" process.
 This process disappear after few seconds but if the option display=attr is
 active, doesn't shut down properly:
 -at every zoom/pan on map the Map display open a new cmd.exe process that
 will never be closed.
 -this trend (adding process) go ahead until the Grass doesn't work and
 stop following comand .
 -even closing Grass before or after its block those process don't
 disappear.
 -the only way in which a user could shut down those process is the windows
 task manager.
 example:
 '' d.vect map=reteF display=shape,attr
 > type=point,area,centroid  attrcol='id' ''
Ticket URL: <http://trac.osgeo.org/grass/ticket/1184>
