[GRASS-dev] SOAP/WSDL and GRASS
Moritz Lennert mlennert at club.worldonline.be
Fri Apr 1 04:38:22 EDT 2011
On 01/04/11 09:40, Davide Perrone wrote:
> Hello everybody. I'm new to GRASS and I have a question for you. I have
> to implement a C++ module to interact with GRASS. If possible I need
> that GRASS was on a remote machine and I have to connect to it and for
> example,for receiving a map, interacting with map, making a calculation
> etc etc...! Is there a Way to do this with WSDL/SOAP? If not....is there
> a way to construct a C++ application that wraps GRASS and use some of
> its functions?
Maybe you could use WPS ? Check out http://grass.osgeo.org/wiki/WPS.
Moritz
