[GRASS-dev] Re: [GRASS GIS] #1244: v.parallel2 error
'Vect_get_point_in_poly()
failed' (was: v.parallel error 'Vect_get_point_in_poly() failed')
trac at osgeo.org
Mon Apr 4 05:49:40 EDT 2011
#1244: v.parallel2 error 'Vect_get_point_in_poly() failed'
Reporter: akbgf | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: v.parallel2 | Platform: Linux
Cpu: x86-32 |
Changes (by mmetz):
* keywords: v.parallel => v.parallel2
Comment:
Applies to v.parallel2 only, v.parallel produces correct output.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1244#comment:1>
