[GRASS-dev] Re: [GRASS GIS] #699: v.buffer2 segfault: in
Vect_get_isle_points()
trac at osgeo.org
Mon Apr 4 06:10:34 EDT 2011
#699: v.buffer2 segfault: in Vect_get_isle_points()
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: closed
Priority: normal | Milestone: 7.0.0
Component: Vector | Version: 6.4.0 RCs
Resolution: fixed | Keywords: v.buffer
Platform: All | Cpu: All
Comment(by mmetz):
Replying to [comment:26 mlennert]:
> However, testing with the other example (see Mon, Oct 9 2006 08:02:33)
from the old RT report gives the following, seems to reveal some remaining
issues.
> First of all, I cannot reproduce the procedure exactly, as the v.buffer
call with bufcolumn=lane_cout gives me
> GRASS 7.0.svn (nc_spm_06):~ > v.buffer vbuf_fill_bug bufcol=lane_count
out=vbuf_fill_bug_lanes scale=150
> ATTENTION : The bufcol option may contain bugs during the cleaning step.
If
> you encounter problems, use the debug option or clean
manually
> with v.clean tool=break; v.category step=0; v.extract -d
> type=area
> ERREUR :The bufcol option requires a valid layer.
> Looking at the table connection info:
> GRASS 7.0.svn (nc_spm_06):~ > v.db.connect -p $OUTMAP
> Vector map <vbuf_fill_bug> is connected by:
> layer <1/vbuf_fill_bug> table <vbuf_fill_bug> in database
</home/mlennert/GRASS/DATA/nc_spm_06/mlennert/dbf/> through driver <dbf>
with key <cat>
> the layer <1/vbuf_fill_bug> looks weird. This should be layer <1>, no ?
(At least it is in dev6).
The syntax is <number>/<name>, nothing wrong there. When using v.buffer(2)
with the bufcolumn option, layer must be specified because it defaults to
all layers (-1). Without the bufcolumn option, all features of the
selected type should be buffered, also those without category in one of
the map's layers.
Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/699#comment:28>
