[GRASS-dev] Re: [GRASS GIS] #699: v.buffer2 segfault: in Vect_get_isle_points()
GRASS GIS trac at osgeo.org
Mon Apr 4 10:19:41 EDT 2011
  Reporter:  neteler  |       Owner:  grass-dev@…
      Type:  defect   |      Status:  closed
  Priority:  normal   |   Milestone:  7.0.0
 Component:  Vector   |     Version:  6.4.0 RCs
Resolution:  fixed    |    Keywords:  v.buffer
  Platform:  All      |         Cpu:  All
Comment(by mmetz):
 Replying to [comment:29 mlennert]:
 [snip]
 > > It seems v.buffer2 has issues with the test cases described in the old
 RT bug 2765 whereas v.buffer does not...
 > Just tested in dev6: I actually don't see any difference between
 v.buffer and v.buffer2 with the two test cases mentioned above. Both work
 fine.
 So the segfault in G7 needs to be explained. BTW, works fine for me in G7.
 > And I still support Markus in replacing v.buffer2 by v.buffer. I know
 this will be frustrating to see a SoC project apparently disappear, but
 IIUC, Markus has actually integrated some of the code into v.buffer, or ?
 Yes, the solution for the buffer column bug has been adapted from
 v.buffer2 to v.buffer. And it is indeed frustrating to disable a GSoC
 project output. I started with v.buffer2, but I do not understand relevant
 parts of the code in buffer2.c, dgraph.[c|h], e_intersect.[c|h], all in
 lib/vector/Vlib/, so I went for the older v.buffer. Maybe someone else has
 more success.
 Anyway, the lesson learned is that GSoC needs more thorough quality
 control before broken modules end up in a stable release branch.
 Markus M
Ticket URL: <https://trac.osgeo.org/grass/ticket/699#comment:30>
