[GRASS-dev] Re: [GRASS GIS] #1099: GRASS 6.4SVN with MSYS fails to start startup screen
GRASS GIS trac at osgeo.org
Thu Apr 7 09:36:49 EDT 2011
 Reporter:  marisn           |       Owner:  grass-dev@…
     Type:  defect           |      Status:  new
 Priority:  normal           |   Milestone:  6.4.1
Component:  Default          |     Version:  svn-releasebranch64
 Keywords:  wingrass, wxgui  |    Platform:  MSWindows Vista
      Cpu:  Unspecified      |
Changes (by marisn):
  * keywords:  wingrass => wingrass, wxgui
Comment:
 This issue seems to be caused by "clever" $HOME tricks by MSYS (?). $HOME
 is set to /home/%USERNAME% and it points to "C:\Program Files\GRASS
 6.4.SVN\msys\%USER%". The catch - there is no such folder as %USER% as
 %USER% migh not have permission to mkdir there. MSYS deals with it just
 fine - it "fools" every call that folder exists. Still it doesn't help
 Python or TCL, as they bypass MSYS and thus don't see MSYS dirty $HOME
 tricks.
 Working solution for Vista users is to add following line to beginning of
 the msys.bat file (seems to work OK also if %USERPROFILE% contains
 spaces):
 set HOME=%USERPROFILE%
 Here's some output for a new user "tests2" under Vista running 04.06.
 WinGRASS 6.4. (without %USERPROFILE% workaround and with some echo's and
 print's):
 Hit RETURN to continue
 Starting GRASS ...
 GISBASE /C/Program Files/GRASS 6.4.SVN
 ^^EXISTS
 GISRC /tmp/grass6-tests2-5624/gisrc
 ^^EXISTS
 GISRCRC /home/tests2/.grassrc6
 ^^DOESNT
 And now calling gis_set.py....
 The current directory is invalid.
 preferences.py#679:gisenv={}
 os.getcwd=C:\PROGRA~1\GRASS6~1.SVN\msys\home\tests2
   File "c:/Program Files/GRASS 6.4.SVN/etc/wxpython/gis_set.py", line 38,
 in <module>
     import gui_modules.goutput
   File "c:/osgeo4w/usr/src/grass64_release/dist.i686-pc-
 mingw32/etc/wxpython/gui_modules/goutput.py", line 37, in <module>
   File "c:\Program Files\GRASS
 6.4.SVN\etc\wxpython\gui_modules\preferences.py", line 941, in <module>
     globalSettings = Settings()
 6.4.SVN\etc\wxpython\gui_modules\preferences.py", line 613, in __init__
     self.ReadSettingsFile()
 6.4.SVN\etc\wxpython\gui_modules\preferences.py", line 680, in
 ReadSettingsFile
     gisdbase = gisenv['GISDBASE']
 KeyError: 'GISDBASE'
 Error in GUI startup. If necessary, please
 report this error to the GRASS developers.
 Switching to text mode now.
 Hit RETURN to continue...
 Here's some output of gis.m after changing startup to use -tcltk instead
 of -wxpython (mentioned directory really doesn't exist):
 couldn't change working directory to
 "C:/PROGRA~1/GRASS6~1.SVN/msys/home/tests2": no such file or directory
     while executing
 "cd $currdir"
     (procedure "MapCanvas::composite" line 24)
     invoked from within
 "MapCanvas::composite $mon"
     (procedure "MapCanvas::drawmap" line 40)
     invoked from within
 "MapCanvas::drawmap $mon"
     (procedure "MapCanvas::display_server" line 9)
     invoked from within
     ("after" script)
Ticket URL: <http://trac.osgeo.org/grass/ticket/1099#comment:8>
