[GRASS-dev] Re: [GRASS GIS] #1300: WxGUI measure tool gives wrong results
GRASS GIS trac at osgeo.org
Sat Apr 9 23:17:02 EDT 2011
 Reporter:  marisn        |       Owner:  martinl
     Type:  defect        |      Status:  assigned
 Priority:  blocker       |   Milestone:  6.4.1
Component:  wxGUI         |     Version:  svn-releasebranch64
 Keywords:  measure tool  |    Platform:  MSWindows Vista
      Cpu:  Unspecified   |
Comment(by hamish):
 Replying to [comment:8 martinl]:
 > hopefully fixed in r45883 (and backported to devbr6).
 thanks, that passes the 'd.grid 5000' test in spearfish,simple_xy loc'ns +
 latest 6.5svn. no difference with using the 'constrain' tick box in prefs
 AFAICT.
 lat/lon is still reporting meaningless results, in grass7 it should use
 m.measure to do the calc so geodesic distance is automatically used if
 needed.
 (which is basically what I wrote the earlier m.distance.py SWIG version
 for*; see also discussion with Radim in the last week about adding a small
 sleep to QGIS's r.what mouse-over queries so process doesn't get launched
 1000 times per mouse movement)
 [*] source:grass/trunk/swig/python/examples/m.distance.py at 43200
 cheers,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1300#comment:9>
