Hi all, I would propose adding non-fatal error reporting function to gislib. New G_error() would act in the similar way as G_fatal_error() except of calling exit(). Currently if you want to report error message without calling exit() you need to use G_warning() instead. Martin -- Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
