[GRASS-dev] [GRASS GIS] #1346: v.in.ascii support for IEEE fp nan,
inf
trac at osgeo.org
Wed Apr 13 02:30:37 EDT 2011
#1346: v.in.ascii support for IEEE fp nan, inf
Reporter: hamish | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: minor | Milestone: 6.4.2
Component: Vector | Version: svn-trunk
Keywords: v.in.ascii | Platform: All
Cpu: All |
Issue migrated here from the old RT bug system # 2763, and trac #198.
http://intevation.de/rt/webrt?serial_num=2763
Fri, Dec 3 2004 Hamish wrote:
> I want to input "nan" into a double precision column, it complains
> "column foo defined as double has string values"
> 'nan' and 'inf' are valid IEEE float/double values;
> scanf "%f" reads them, etc.
Radim replied:
> Added to my TODO > 6.0
Markus:
> please try 'NULL' instead of 'nan'.
doesn't work. turns the column into string even if defined as double with
columns=
H:
> nan, inf are valid float/double values and should be scanned as such
> from incoming raw float data. AFAIK sscanf does read it as a valid %f.
> My current work around is:
> sed -e 's/nan//g'
Jul 8 2006 Markus suggested:
if(column= type is specified as double prec)
> G_str_replace(incoming line, "nan", "");
but it would be good to also catch "inf", "NaN", and perhaps "NULL".
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1346>
