[GRASS-dev] XDRIVER
roger at spinn.net
roger at spinn.net
Wed Apr 13 17:55:09 EDT 2011
Regarding R_get_text_box(), in all of my tests the width of the text box was
wrong.
Also, main.c in d.text.new (6.4.0RC5) contains the comment
/* TODO: get text dimension */
/* R_get_text_box() does not work with rotation and returns a little bit
* bigger dimension than actual text size */
I don't know the vintage of that comment. The problem isn't consistent;
neither d.vect nor d.labels seems to have the same problem, so it was likely
to be some detail of my implementation that I was never able to find and
fix.
Roger
Glynn Clements writes:
> roger at spinn.net wrote:
>> I'm aware that XDRIVER is antiquated piece of software that the project does
>> not intend to use for it's primary display or interactive tool. I have two
>> main questions (and maybe some to follow up):
>> Does the project intend to retain XDRIVER in the distribution?
>> Are there any plans to update or upgrade XDRIVER?
> No. Monitors (display drivers as separate processes) have been removed
> entirely (and permanently) from 7.0.
> There doesn't seem to be much point in making significant changes in
> 6.x, given that it's a dead end. Also, monitors (all monitors, not
> just XDRIVER) don't work on Windows.
> I'm not sure what problems you were having with R_get_text_box(), but
> if we can identify a bug, that should be fixed.
> Glynn Clements <glynn at gclements.plus.com>
