[GRASS-dev] Re: [GRASS GIS] #982: Vector modules changing db should call Vect_set_db_updated
GRASS GIS trac at osgeo.org
Mon Apr 18 06:31:24 EDT 2011
 Reporter:  rblazek      |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  6.4.0
Component:  Vector       |     Version:  unspecified
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by mlennert):
 See attached patch for an implementation of Radim's suggestion of adding a
 flag to v.db.connect which call Vect_set_db_updated(). Scripts that change
 the attibute file could then call 'v.db.connect -u map=' to signal the
 update of the attribute file.
 The diff is against dev6, but should be easily applicable in the other
 branches.
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/982#comment:5>
