[GRASS-dev] library so file name scheme and GDAL-GRASS plugin
Martin Landa
landa.martin at gmail.com
Mon Apr 18 15:41:58 EDT 2011
2011/4/18 Markus Neteler <neteler at osgeo.org>:
> I don't know what changed but I don't manage any more to compile the
> GDAL-GRASS-plugin without tricks:
> config.log of GDAL-GRASS-plugin:
> configure:3017: checking for G_putenv in -lgrass_gis
> configure:3047: gcc -o conftest -O2 conftest.c -lgrass_gis
> -L/home/neteler/grass64/dist.x86_64-unknown-linux-gnu/lib
> -lgrass_gmath -lgrass_gis -lgrass_datetime -lgrass_gproj -lgrass_vect
> -lgrass_dbmibase -lgrass_dbmiclient -lgrass_dgl -lgrass_dig2
> -lgrass_rtree -lgrass_linkm -L/usr/local/lib -lgdal >&5
> /usr/bin/ld: cannot find -lgrass_gis
> /usr/bin/ld: cannot find -lgrass_gmath
> /usr/bin/ld: cannot find -lgrass_datetime
> /usr/bin/ld: cannot find -lgrass_gproj
> /usr/bin/ld: cannot find -lgrass_vect
> /usr/bin/ld: cannot find -lgrass_dbmibase
> /usr/bin/ld: cannot find -lgrass_dbmiclient
> /usr/bin/ld: cannot find -lgrass_dgl
> /usr/bin/ld: cannot find -lgrass_dig2
> /usr/bin/ld: cannot find -lgrass_rtree
> /usr/bin/ld: cannot find -lgrass_linkm
> All names are currently libgrass_raster.6.4.2svn.so and likewise.
> Starting gdalinfo etc, tells me
> libgrass_I.so not found
> I can solve the problem like this:
> cd /where/grass64/is/lib/
> for i in `ls libgrass_*.6.4.*` ; do ln -s $i `basename $i 6.4.2svn.so`so ; done
building system in GRASS 7 doesn't produce unversioned library names.
Symlinks don't work on Windows, this change has been backported some
months ago to devbr6 and recently also to relbr64 (for 6.4.2).
GDAL-GRASS-plugin needs to updated (to use only versioned library
names).
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
