[GRASS-dev] library so file name scheme and GDAL-GRASS plugin
Markus Neteler
neteler at osgeo.org
Mon Apr 18 15:58:00 EDT 2011
On Mon, Apr 18, 2011 at 9:50 PM, Martin Landa <landa.martin at gmail.com> wrote:
> Hi,
> 2011/4/18 Markus Neteler <neteler at osgeo.org>:
>>> GDAL-GRASS-plugin needs to updated (to use only versioned library
>>> names).
>> This is fairly unlikely to happen (in GDAL) so many packagers may start
>> to drop this important plugin.
> why do you think so.
Because in the past it was not so easy to get changes to the plugin through
and my patches for GRASS 7 are sleeping in the GDAL trac for already
2 years..:
http://trac.osgeo.org/gdal/ticket/2953
>> Suggestion: Create the symlinks on Linux and MacOSX only with a
>> condition.
> Probably yes.
Then that would be the "least cost" path IMHO rather than bothering elsewhere.
Markus
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
