[GRASS-dev] Re: [GRASS GIS] #1349: Ps.map supports only english
trac at osgeo.org
Wed Apr 20 15:26:16 EDT 2011
Reporter: annakrat | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: minor | Milestone: 6.5.0
Component: Ps.map | Version: unspecified
Keywords: encoding | Platform: Unspecified
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:1 hamish]:
> do you wish to have a translated version of one of the existing distance
formats, or to use one not on the current list?
I meant the translated version.
> In general I'm not much of a fan of hard-results depending on the locale
setting (harms ability to rely on reproducible results), but the above
patch seems reasonable enough to me.
> does it solve the wish?
I'm not sure about this solution. If it would be dependend on locale
settings and I would like to create map output in different language than
in locale settings, is there a way to set language?
Another problem is that now I can't write czech labels to map because
latin1 doesn't support some accented characters. And if I understand the
previous comments well, this problem is not going to be fixed. As a result
there's no need to have translated units. But users speaking other
languages (where Latin1 is OK) may appreciate this.
What about adding the possibility of custom unit label (given by user),
which would solve the problems with translation and enables to use
abbreviations (like m, km)?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1349#comment:4>
