[GRASS-dev] Re: [GRASS GIS] #1158: Removing vector map in Windows
fails with "Unable to delete vector map"
trac at osgeo.org
Fri Apr 22 11:55:13 EDT 2011
#1158: Removing vector map in Windows fails with "Unable to delete vector map"
Reporter: lponti | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.2
Component: Vector | Version: 6.4.0
Keywords: wingrass, g.mremove, wildcards, v.in.ogr, v.select, g.remove | Platform: MSWindows 7
Cpu: Unspecified |
Comment(by glynn):
Replying to [comment:30 mmetz]:
> > I know that they '''shouldn't''' be open, but are they? See comment:3.
> OK. I suggest Vect!__open_old() and Vect_open_new() should initialize
all file pointers to NULL and Vect_close() should close anything that is
not NULL.
That won't help if the problem is being caused by the DBMI driver
inheriting the descriptor and not terminating before the file is deleted.
I don't know if this is what's causing the problem, but there appear to be
cases where it can happen.
> Unfortunately, G_zero() does not set all contents of the Map_info
structure to 0 or NULL
How come?
Ticket URL: <https://trac.osgeo.org/grass/ticket/1158#comment:34>
