[GRASS-dev] [GRASS GIS] #1353: ./configure with ffmpeg x86_64 - problem, with workaround
GRASS GIS trac at osgeo.org
Sat Apr 30 07:48:07 EDT 2011
 Reporter:  geep999  |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:
Component:  Default  |     Version:  6.4.1 RCs
 Keywords:           |    Platform:  Linux
      Cpu:  x86-64   |
 I have a bug and workaround for grass 6.4.1 ./configure with ffmpeg on
 Slackware 13.37 x86_64
 ./configure \
 --with-ffmpeg \
 --with-ffmpeg-includes="/usr/include/libpostproc /usr/include/libswscale
 /usr/include/libavcodec \
 /usr/include/libavdevice /usr/include/libavfilter /usr/include/libavformat
 /usr/include/libavutil" \
 --with-ffmpeg-libs="/usr/lib64"
 I get error messages like:
 checking whether to use FFMPEG...
 yes
 checking for location of FFMPEG includes... /usr/include/libpostproc
 /usr/include/libswscale /usr/include/libavcodec
 /usr/include/libavformat /usr/include/libavutil
 checking for avcodec.h... yes
 checking for avformat.h... yes
 checking for swscale.h... yes
 checking for location of FFMPEG library... /usr/lib64
 checking for av_free in -lavutil... yes
 checking for avcodec_init in -lavcodec... yes
 checking for av_set_parameters in -lavformat... no
 configure: error: *** Unable to locate FFMPEG library.
 This happens because ./configure is looking for:
 /usr/lib64/libavcodec.so /usr/lib64/libavformat.so /usr/lib64/libavutil.so
 But on my 64bit Slackware 13.37 they are installed in:
 /usr/lib64/libavcodec64.so /usr/lib64/libavformat64.so
 /usr/lib64/libavutil64.so
 Making soft links cures the problem, but perhaps ./configure could be
 upgraded.
 cd /usr/lib64
 ln -s libavformat64.so libavformat.so
 ln -s libavcodec64.so libavcodec.so
 ln -s libavutil64.so libavutil.so
 I am not sure yet if I should also have created soft links for:
 '''libswscale64.so libpostproc64.so libavdevice64.so libavfilter64.so'''
 but they are not needed in order to get ./configure to run.
 [[BR]]
 Keep up the good work.
 [[BR]]
 Cheers,
 [[BR]]
 Peter
Ticket URL: <http://trac.osgeo.org/grass/ticket/1353>
