[GRASS-dev] [GRASS GIS] #1416: wingrass7 nightly build crash on start
GRASS GIS trac at osgeo.org
Tue Aug 2 08:54:06 EDT 2011
 Reporter:  MilenaN  |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  7.0.0
Component:  Startup  |     Version:  svn-trunk
 Keywords:           |    Platform:  MSWindows 7
      Cpu:  x86-64   |
 wingrass7 behaves in a strange way on start:
 1. It starts in a minimised window, so the user is not sure if anything
 happened after clicking the grass icon.
 2. When the (windows) user finds eventually the minimised grass window and
 makes it bigger, the cmd window (!) appears, encouraging him gently to
 "Hit RETURN to continue" (what on earth RETURN is, the user thinks).
 3. Finally Welcome window appears but no grass database can be found (when
 grass 64 and 65 have no problem with it on the same pc). Pointed to the
 path, grass crasches with the following message in cmd:
   File "C:\Program Files (x86)\GRASS 7.0.SVN\etc\gui\wxpython\gis_set.py",
 line
 877, in <module>
     GRASSStartUp = StartUp(0)
   File "c:\OSGeo4W\apps\Python25\lib\site-packages\wx-2.8-msw-
 unicode\wx\_core.p
 y", line 7935, in __init__
     self._BootstrapApp()
 unicode\wx\_core.p
 y", line 7509, in _BootstrapApp
     return _core_.PyApp__BootstrapApp(*args, **kwargs)
 line
 862, in OnInit
     StartUp.OnBrowse(None)
 line
 697, in OnBrowse
     self.OnSetDatabase(event)
 line
 686, in OnSetDatabase
     self.OnSelectLocation(None)
 line
 635, in OnSelectLocation
     self.listOfLocations[self.lblocations.GetSelection()]))
 line
 599, in UpdateMapsets
     gisdbase = self.gisdbase)
   File "c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
 mingw32/etc/gui/wxpython/gui
 _modules/gcmd.py", line 610, in RunCommand
 _modules/gcmd.py", line 610, in <lambda>
 _modules/utils.py", line 664, in DecodeString
 7.0.SVN\Python25\lib\encodings\utf_8.py", l
 ine 16, in decode
     return codecs.utf_8_decode(input, errors, True)
 UnicodeDecodeError: 'utf8' codec can't decode byte 0xa3 in position 26:
 unexpect
 ed code byte
 Error in GUI startup. If necessary, please report this error to the GRASS
 develo
 pers.
 Switching to text mode now.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1416>
