[GRASS-dev] [GRASS GIS] #1418: WinGrass7 - v,dissolve not working
trac at osgeo.org
Sat Aug 6 16:37:58 EDT 2011
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.0
Component: Vector | Version: svn-trunk
Keywords: wingrass | Platform: MSWindows Vista
Cpu: x86-32 |
tested with WinGRASS-7.0.SVN-r47463-1-Setup.exe
there are a few issues with v.dissolve
(1) db.tables in $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db
db.tables --verbose
EU27_Biogeo_June08
bgr58fus
br05exploded
br05explodedl1
(Sat Aug 06 22:18:19 2011) Command finished (0 sec)
(2) db.describe --verbose table=bgr58fus
column:bgr0508fus
description:
type:CHARACTER
len:75
scale:0
precision:0
default:
nullok:yes
select:?
update:?
(3) v.dissolve from the wxgui
File "C:\Program Files\GRASS
7.0.SVN\etc\gui\wxpython\wxgui.py", line 536, in OnMenuCmd
menuform.GUI(parent = self).ParseCommand(cmd)
7.0.SVN\etc\gui\wxpython\gui_modules\menuform.py", line
1878, in ParseCommand
blackList = _blackList)
File "c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-
mingw32/etc/python/grass/script/task.py", line 451, in
parse_interface
mingw32/etc/python/grass/script/task.py", line 438, in
get_interface_description
grass.script.core
ScriptError
u'Unable to fetch interface description for command
\'v.dissolve\'.\n\nDetails: Traceback (most recent call
last):\r\n File "C:\\Program Files\\GRASS
7.0.SVN\\scripts\\v.dissolve.py", line 39, in <module>\r\n
import grass.script as grass\r\n File "C:\\Program
Files\\GRASS
7.0.SVN\\etc\\python\\grass\\script\\__init__.py", line 1,
in <module>\r\n from core import *\r\n File
7.0.SVN\\etc\\python\\grass\\script\\core.py", line 31, in
<module>\r\n import subprocess\r\n File "C:\\Program
Files\\GRASS 7.0.SVN\\Python25\\lib\\subprocess.py", line
376, in <module>\r\n import threading\r\n File
7.0.SVN\\Python25\\lib\\threading.py", line 13, in
<module>\r\n from collections import
deque\r\nImportError: No module named collections\r\n'
(4) from the wxgui-command console
mingw32/etc/gui/wxpython/gui_modules/prompt.py", line 803,
in OnItemSelected
parse_interface
grass.script.core
ScriptError
Files\\GRASS
(5) and in the wingrass70-windows-commandline
GRASS 7.0.svn> v.dissolve.py input=bgr58fus layer=1 column=bgr0508fus
output=bgrdis
DBMI-SQLite driver error:
Cannot step:
SQL logic error or missing database
FEHLER: Kann Daten nicht aus der Tabelle <bgr58fus> holen.
FEHLER: Vektorkarte <bgrdis> nicht gefunden.
GRASS 7.0.svn>
there seems to be some issue with the sqlite-database
best regards
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1418>
