[GRASS-dev] switch active window on Map Display
Martin Landa
landa.martin at gmail.com
Tue Aug 9 03:44:48 EDT 2011
2011/8/8 Wenzeslaus <wenzeslaus at gmail.com>:
> I have general note to this. Maybe it is common problem that someone
> want to get current Map Display. So some simple getter function should
> be introduced:
> class GMFrame(wx.Frame):
> def GetCurrentMapDisplay():
> """!Returns current Map Display window"""
> return self.parent.curr_page.maptree.mapdisplay
probably yes, anyway you can write
GetLayerTree().GetMapDisplay()
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
