[GRASS-dev] Re: [SoC] Weekly report #10 r.modis GRASS
Markus Neteler neteler at osgeo.org
Tue Aug 9 06:01:49 EDT 2011
On Tue, Aug 9, 2011 at 10:27 AM, Hamish <hamish_b at yahoo.com> wrote:
> Luca wrote:
>> Here [0] you can find my weekly report
>> [0] http://grass.osgeo.org/wiki/R.modis_GSoC_2011#.2310_2011-08-05
>> regards
>> Luca
>> http://gis.cri.fmach.it/delucchi/
>> www.lucadelu.org
> Hi Luca,
> regarding the problem with swath2grid, anything we can help
> with? what's the problem you are stuck on? maybe someone here
> has a bright idea to get past it.
Attached the result of a run, here some excerpt of the log file:
Processing LST ...
  output lines/samples: 31819 2374
  output pixel size: 0.0100
  output data type: same as input
  output upper left corner: lat  172.35803100  long  -79.58354300
  output lower right corner: lat -145.82196900  long  -55.85354300
  input lines/samples: 2030 1354
  input resolution: 1 km
  %% complete: 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100%
The map is spatially completely out of range.
Markus (GSoC mentor)
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20110809/fbc74a56/modis_swath_reprojection_result-0001.png
