[GRASS-dev] G7: parser - suppressing label in scripts
Markus Neteler
neteler at osgeo.org
Wed Aug 10 09:19:35 EDT 2011
we have a problem with the introduction of labels:
http://trac.osgeo.org/grass/changeset/39886/grass/trunk/lib/gis/parser_standard_options.c
because:
myscript.py help
vector Name of input vector map(s) used by GRASS script
Data source(s) for direct OGR access
... but we don't want the second line.
It would be good to be able to suppress "label" with the a reserved word
like "None" or "NULL":
#%option G_OPT_V_INPUTS
#% key: vector
#% label: NULL
#% description: Name of input vector map(s) used by GRASS script
#% required: no
#%end
to eventually gain:
myscript.py help
Any suggestions how to implement this suppressing "label" in the parser?
Markus
