[GRASS-dev] i.topo.corr ported to GRASS 7
Fri Aug 12 03:29:44 EDT 2011
Markus Neteler wrote:
> This problem remains:
> i.topo.corr input=myplane_pyr_band output=myplane_pyr_topocorr_percent
> basemap=myplane_pyr_illumination zenith=45.652668 method=percent
> Band myplane_pyr_band:
> ERROR: Input window changed while maps are open for read
You fixed the first occurrence of G_get_set_window() in
illumination.c, in eval_c_cosi(), but missed the others, in
eval_f_cosi() and eval_d_cosi().
BTW, does it really need three separate versions of what appears to be
essentially the same function?
