Glynn: > The iostream library uses size_t. However, r.terraflow > itself had a bug (scale then cast instead of cast then scale), > which should be fixed by r47641. in the same class, but sort of unrelated- any thoughts on #1107? https://trac.osgeo.org/grass/ticket/1107 thanks, Hamish
