[GRASS-dev] problem with Rast_get_c_color()
Tue Aug 16 18:42:52 EDT 2011
Markus Neteler wrote:
> > > thanks for the clarification. I chose the first case, see r47671.
> > also backported (r47672) to devbr6 for testing.
> What would be the test case?
You'll either need to write one, or find some way to extend the range
of values in a map *without* extending the map's colour table;
"r.null ... null=<max+1>" might work.
