[GRASS-dev] Re: wxGUI: MapDisplay mouse events
Wenzeslaus
wenzeslaus at gmail.com
Wed Aug 17 17:13:22 EDT 2011
Hi Michael,
it is file with patch
mapdisplay_mouse_events.diff
and simple example how to use API also in diff file
mapdisplay_mouse_events_example.diff
I'm not sure why, but mailing list thinks that MIME type text/x-patch
is a binary file. Then it produces the text and links you see. Some
mail clients can handle it and instead of links they displays
attachments but some cannot.
I don't understand it completely and I don't know how to avoid it.
I'll try to attach the patch with txt suffix to find out how it works.
Vasek
On 17 August 2011 20:06, Michael Barton <michael.barton at asu.edu> wrote:
> Vasek,
> What are the *.bin files that download from your html links?
> Michael
Index: gui_modules/mapdisp_window.py
--- gui_modules/mapdisp_window.py (revision 47653)
+++ gui_modules/mapdisp_window.py (working copy)
@@ -49,6 +49,7 @@
Superclass for BufferedWindow class (2D display mode), and GLWindow
(3D display mode).
+ Subclasses have to define _bindMouseEvents() method which binds MouseEvent handlers.
def __init__(self, parent, id = wx.ID_ANY,
Map = None, tree = None, lmgr = None, **kwargs):
@@ -65,7 +66,89 @@
'use' : "pointer",
'box' : "point"
+ # stores overriden cursor
+ self._overridenCursor = None
+ def RegisterMouseEventHandler(self, event, handler, cursor = None):
+ """!Binds event handler
+ Call event.Skip() in handler to allow default processing in MapWindow.
+ \code
+ # your class methods
+ def OnButton(self, event):
+ # current map display's map window
+ # expects LayerManager to be the parent
+ self.mapwin = self.parent.GetLayerTree().GetMapDisplay().GetWindow()
+ if self.mapwin.RegisterMouseEventHandler(wx.EVT_LEFT_DOWN, self.OnMouseAction,
+ wx.StockCursor(wx.CURSOR_CROSS)):
+ self.mapwin.Raise()
+ else:
+ # handle that you cannot get coordinates
+ def OnMouseAction(self, event):
+ # get real world coordinates of mouse click
+ coor = self.mapwin.Pixel2Cell(event.GetPositionTuple()[:])
+ self.text.SetLabel('Coor: ' + str(coor))
+ self.mapwin.UnregisterMouseEventHandler(wx.EVT_LEFT_DOWN)
+ event.Skip()
+ \endcode
+ @param event one of mouse events
+ @param handler function to handle event
+ @param cursor cursor which temporary overrides current cursor
+ @return True if successfull
+ @return False if event cannot be bind
+ # if it is a VDigitWindow it cannot be used
+ # hasattr is ugly
+ if hasattr(self, "digit"):
+ return False
+ self.Bind(event, handler)
+ self.mouse['useBeforeGenericEvent'] = self.mouse['use']
+ self.mouse['use'] = 'genericEvent'
+ if cursor:
+ self._overridenCursor = self.GetCursor()
+ self.SetCursor(cursor)
+ return True
+ def UnregisterMouseEventHandler(self, event):
+ """!Unbinds event handler a restores previous state
+ You should unbind to restore normal MapWindow behaviour.
+ Note that this operation will unbind any other external (non-MapWindow) handlers.
+ @param event event to unbind
+ @return False if event cannot be unbind
+ return False
+ # it is not yet posible in wxPython to unbind exact event
+ ret = self.Unbind(event)
+ # restore bind state
+ self._bindMouseEvents()
+ # restore mouse use (previous state)
+ self.mouse['use'] = self.mouse['useBeforeGenericEvent']
+ # restore overriden cursor
+ if self._overridenCursor:
+ self.SetCursor(self._overridenCursor)
+ return ret
def OnMotion(self, event):
"""!Track mouse motion and update statusbar
@@ -223,8 +306,7 @@
self.Bind(wx.EVT_PAINT, self.OnPaint)
self.Bind(wx.EVT_SIZE, self.OnSize)
self.Bind(wx.EVT_IDLE, self.OnIdle)
- self.Bind(wx.EVT_MOUSE_EVENTS, self.MouseActions)
- self.Bind(wx.EVT_MOTION, self.OnMotion)
self.processMouse = True
@@ -276,6 +358,10 @@
# pseudoDC for temporal objects (select box, measurement tool, etc.)
self.pdcTmp = wx.PseudoDC()
+ def _bindMouseEvents(self):
+ self.Bind(wx.EVT_MOUSE_EVENTS, self.MouseActions)
+ self.Bind(wx.EVT_MOTION, self.OnMotion)
def Draw(self, pdc, img = None, drawid = None, pdctype = 'image', coords = [0, 0, 0, 0]):
"""!Draws map and overlay decorations
Index: gui_modules/nviz_mapdisp.py
--- gui_modules/nviz_mapdisp.py (revision 47653)
+++ gui_modules/nviz_mapdisp.py (working copy)
@@ -151,9 +151,8 @@
self.Bind(wx.EVT_ERASE_BACKGROUND, self.OnEraseBackground)
- self.Bind(wx.EVT_MOUSE_EVENTS, self.OnMouseAction)
self.Bind(EVT_UPDATE_PROP, self.UpdateMapObjProperties)
self.Bind(EVT_UPDATE_VIEW, self.UpdateView)
@@ -168,6 +167,10 @@
def __del__(self):
self.UnloadDataLayers(force = True)
+ self.Bind(wx.EVT_MOUSE_EVENTS, self.OnMouseAction)
def InitCPlanes(self):
"""!Initialize cutting planes list"""
for i in range(self._display.GetCPlanesCount()):
