[GRASS-dev] Re: wxGUI: MapDisplay mouse events
Wenzeslaus wenzeslaus at gmail.com
Thu Aug 18 03:57:57 EDT 2011
Michael,
as far as I know, now if you want to get mouse click coordinates from
MapDisplay (MapWindow) you have to edit file mapdisp_window.py (for 2D
mode) and nviz_mapdisp.py (if you also want coordinates from 3D).
With my suggested API there is no need to edit these 'core files'. You
simply register your handler. And it can be done even if you are
writing a addon and you can not change 'core files'.
I don't think that we should change existing code. Some functions
(features) are very connected to MapWindow and very complex and
writing code just into 'core files' is the best solution. But in my
opinion suggested API is the best solution for simple tasks like 'get
mouse click coordinates to MyDialog'.
Vasek
On 17 August 2011 23:21, Michael Barton <Michael.Barton at asu.edu> wrote:
> I need to look at this in more detail, but at first glance, it add another method that does things that are already done by other methods.
> Michael
> ______________________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Arizona State University
> Tempe, AZ  85287-2402
> USA
> voice:  480-965-6262 (SHESC), 480-727-9746 (CSDC)
> fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
> www:    http://csdc.asu.edu, http://shesc.asu.edu
>                http://www.public.asu.edu/~cmbarton
> On Aug 17, 2011, at 2:13 PM, Wenzeslaus wrote:
>> Hi Michael,
>> it is file with patch
>> mapdisplay_mouse_events.diff
>> and simple example how to use API also in diff file
>> mapdisplay_mouse_events_example.diff
>> I'm not sure why, but mailing list thinks that MIME type text/x-patch
>> is a binary file. Then it produces the text and links you see. Some
>> mail clients can handle it and instead of links they displays
>> attachments but some cannot.
>> I don't understand it completely and I don't know how to avoid it.
>> I'll try to attach the patch with txt suffix to find out how it works.
>> Vasek
>> On 17 August 2011 20:06, Michael Barton <michael.barton at asu.edu> wrote:
>>> Vasek,
>>> What are the *.bin files that download from your html links?
>>> Michael
>> <mapdisplay_mouse_events.txt>
