[GRASS-dev] Re: [GRASS GIS] #1110: v.rast.stats locks up on wingrass
trac at osgeo.org
Sat Aug 20 02:10:17 EDT 2011
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Vector | Version: svn-releasebranch64
Keywords: wingrass, v.rast.stats, v.db.addcol, v.info | Platform: MSWindows XP
Cpu: x86-32 |
Comment(by hamish):
a long standing question is why on the same machine it works sometimes but
not others; and why plenty of other scripts can call each other, seemingly
without any trouble..?
some quick examples,
- v.in.lines calls the v.in.mapgen script;
- v.db.renamecol and v.db.join calls the v.db.addcol script.
- the script version of v.colors calls v.db.addcol too.
- r.in.wms & i.oif are a bit different, as they call their own support
scripts outside of the normal path. r.in.wms is a tangle, but i.oif should
be easy enough to work through by hand.
any trouble with those?
are you working from the rxvt/msys prompt? the cmd.exe DOS prompt? from
within the GUI?
does that make a difference?
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1110#comment:5>
