[GRASS-dev] [GRASS GIS] #1424: Profile tool always casts to
integers (incl. csv output)
trac at osgeo.org
Sat Aug 20 02:38:54 EDT 2011
#1424: Profile tool always casts to integers (incl. csv output)
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.2
Component: wxGUI | Version: svn-releasebranch64
Keywords: profile tool, precision | Platform: All
Cpu: All |
as reported on the grass-user mailing list yesterday, export to .csv
always exports as integers, regardless of if the source data is CELL,
FCELL, or DCELL.
Moritz prepared a patch:
--- profile.py 2011-08-19 13:28:17.000000000 +0200
+++ profile_new.py 2011-08-19 13:28:43.000000000 +0200
@@ -598,7 +598,7 @@
caption=_("Error"), style=wx.OK |
wx.ICON_ERROR | wx.CENTRE)
return False
for datapair in r['datalist']:
- file.write('%d,%d\n' %
(float(datapair[0]),float(datapair[1])))
+ file.write('%f,%f\n' %
file.close()
but I think we need to go deeper than that, as `%d` shows up all around
the script, both in preparing the source points to feed into r.profile,
and in processing the results of it.
* Rather importantly in lat/lon locations casting the tie points to int
can silently return the wrong results, with coords shifted a long way from
where you expected.
On the input side it will be easy enough to change `%d` to `%.15g`
(technically `%.9g` would be enough to cover sub-millimeter in lat/lon)
for r.profile and r.what's coord input.
On the output site the distance along transect should be at least to the
mm (`%.3f` or `%.3g` assuming the tool preserves r.profile's column 1
distance as meters), and test for map type, exporting column 2 as `%d` for
CELL, `%.7g` for FCELL, and `%.15g` for DCELL. (see #335)
another thing to keep in mind is that map_units is not always going to be
feet, meters, or degrees. there's little reason it couldn't be microns or
parsecs, so to avoid others being limited by our humble imaginations we
should avoid unnecessary assumptions about that whenever possible.
Hamish
ps- see also #1292 "Profile tool incorrectly processes no data values"
Ticket URL: <https://trac.osgeo.org/grass/ticket/1424>
