[GRASS-dev] Create new branch from trunk for temporal GIS
integration
Martin Landa
landa.martin at gmail.com
Tue Aug 23 02:57:30 EDT 2011
2011/8/22 Soeren Gebbert <soerengebbert at googlemail.com>:
> The reason why i would like to create a branch is the experimental
> character of the implementation.
> I have a big picture about what is needed, but no detailed
> implementation concept. I would like to experiment
> with different implementation approaches. This is IMHO nothing to be
> done in trunk, as it might break compilation
> or several modules because of library changes ... .
> The goal is not to break grass and its functionality, but as i am not
> absolutely sure about the implementation, i can not assure this.
> Using trunk i must be much more careful and disciplined .... making it
> harder to be creative.
in this case I could imagine special branch but only for a short-term
period, in other words merge to trunk ASAP.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
