[GRASS-dev] trunk r47474 breaks OGSF rendering of points on surface
Maris Nartiss maris.gis at gmail.com
Tue Aug 23 04:27:28 EDT 2011
Hello,
thanks, finally I can try out new wxnviz functionality.
Are there any instructions how to run wxnviz under gdb or valgrind to
get out meaningful output? I simply managed to crash it after fourth
mouse click ;)
In case You like to crash it too: start wxgui; as the first thing
switch from 2D to 3D; realize, that You forgot to add any data ->
switch back to 2D; add any raster; switch to 3D -> crash (and burn).
Maris.
2011/8/22 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2011/8/21 Anna Kratochvílová <kratochanna at gmail.com>:
>>> Clean compile of r47738
>>> GUI D5/5: NvizThread.__init__():
>>> D4/5: Rast_unset_window()
>>> D2/5: G__read_Cell_head_array
>>> D3/5: region item: n-s resol: 4.000000
>> I've just got an netbook which crashes in the same moment so I can test it more.
>> It's Ubuntu 10.04, 32bit, python 2.6.5., wxpython 2.8.10.1.
>> lspci gives
>> 00:02.0 VGA compatible controller: Intel Corporation Mobile 4 Series
>> Chipset Integrated Graphics Controller (rev 07)
>> (Actually, I don't know what can affect it)
> with help of Anna, this bug should be fixed in r47833.
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
