[GRASS-dev] Create new branch from trunk for temporal GIS integration
Soeren Gebbert soerengebbert at googlemail.com
Tue Aug 23 04:32:42 EDT 2011
2011/8/23 Markus Neteler <neteler at osgeo.org>:
>>> The reason why i would like to create a branch is the experimental
>>> character of the implementation.
>>> The goal is not to break grass and its functionality, but as i am not
>>> absolutely sure about the implementation, i can not assure this.
>>> Using trunk i must be much more careful and disciplined .... making it
>>> harder to be creative.
>> in this case I could imagine special branch but only for a short-term
>> period, in other words merge to trunk ASAP.
> Soeren, would you be able to keep "your" branch in sync with the pace
> of changes happening in trunk?
Thats the idea, to have a temporary trunk for time integration being
in sync with the main trunk. So the
merge of the temporal extension into trunk will be much easier.
The branch should only exist for experimenting and rapid development
and merged ASAP.
Best regards
Soeren
