[GRASS-dev] Re: [GRASS GIS] #1110: v.rast.stats locks up on wingrass
GRASS GIS trac at osgeo.org
Tue Aug 23 06:48:43 EDT 2011
 Reporter:  hamish                                       |       Owner:  grass-dev@…
     Type:  defect                                       |      Status:  new
 Priority:  critical                                     |   Milestone:  6.4.2
Component:  Vector                                       |     Version:  svn-releasebranch64
 Keywords:  wingrass, v.rast.stats, v.db.addcol, v.info  |    Platform:  MSWindows XP
      Cpu:  x86-32                                       |
Comment(by hellik):
 Replying to [comment:10 hellik]:
 > adding \bin and \scripts to the %PATH% to
 > C:\Program Files\GRASS 6.4.SVN\etc\env.bat
 > helps v.rast.stat to invoke v.db.addcol in the grass64svn.bat-case
 v.rast.stats vector=mylakes at g7 raster=elevation at PERMANENT colprefix=pahk
 Processing data (766 categories)...
 Updating the database ...
 Statistics calculated from raster map <elevation at PERMANENT> and uploaded
 to     attribute table of vector map <mylakes>.
 Done.
 (Tue Aug 23 12:34:46 2011) Befehl ausgeführt (1657 sec)
 so adding to the path seems to be solution...
 Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1110#comment:11>
