[GRASS-dev] Re: [GRASS GIS] #1110: v.rast.stats locks up on wingrass
trac at osgeo.org
Tue Aug 23 10:04:10 EDT 2011
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Vector | Version: svn-releasebranch64
Keywords: wingrass, v.rast.stats, v.db.addcol, v.info | Platform: MSWindows XP
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:4 hellik]:
> tested with WinGRASS-6.4.SVN-r47756-1-Setup.exe
> there seems to be 2 issues here:
> (1) v.rast.stats seems not to be able to invoke v.db.addcol
> which is in C:\Program Files\GRASS 6.4.SVN\scripts and has
> a wrapper script in C:\Program Files\GRASS 6.4.SVN\bin\v.db.addcol.bat
> Replying to [comment:1 hamish]:
> > Yvan wrote:
> > C:/GRASS-64-SVN/scripts/v.rast.stats: line 268: v.db.addcol:
> > command not found
> > ERROR: Cannot continue (problem adding columns).
with the path-addition this issue seems to be solved
> (2) v.db.addcol seems not to be able to add a column in windows with
> the dbf-driver, but it's able with the sqlite-driver
all tests above with sqlite as db-backend are working here in all
different wingrass-starting cases.
switching to '''dbf''' as db-backend:
(1) v.rast.stats in the "C:\Program Files\GRASS 6.4.SVN\msys\msys.bat"
/grass/bin/grass64svn -wxpython"-case seems to work here
but
(2) v.rast.stats in grass64svn.bat-case wingrass freezes
Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1110#comment:14>
