[GRASS-dev] NVIZ problem with 3D polygons
del cadarn
del_cadarn at hotmail.com
Thu Aug 25 04:18:16 EDT 2011
Dear Mr. Neteler,
thank you for your input (and for your book about Grass, without which I don't know how I would approach Grass... actually I'm borrowing my employer's copy so if you have any free ones floating around... ;) ).
Your solution worked for the v.extrude buildings... brilliant.
However it doesn't work for the imported DXF, here is a description of the details
| Number of points: 0 Number of areas: 0 |
| Number of lines: 0 Number of islands: 0 |
| Number of boundaries: 0 Number of faces: 53516 |
| Number of centroids: 0 Number of kernels: 0 |
| Map is 3D: Yes |
| Number of dblinks: 1
Do I need to apply v.type on another categorie?
Thank you,
DelphineJB
Date: Tue, 16 Aug 2011 11:57:20 +0200
Subject: Re: [GRASS-dev] NVIZ problem with 3D polygons
To: del_cadarn at hotmail.com
CC: grass-dev at lists.osgeo.org
On Thu, Aug 11, 2011 at 11:30 AM, del cadarn <del_cadarn at hotmail.com> wrote:
Bonjour,
I've also posted this on the GRASS-users mailist but since I didn't receive an answer, I thought I might try this one.
Sorry, I overlooked it.
I am having problems to see vectors I have added height to with
v.extrude . The trick is that I am actually using the e.g. given in
NETELER, M and H. MITASOVA Open Source GIS a GRASS GIS Approach with the North Carolina sample data. So in theory, this example should really be working...
Thanks :) But there was an error in that part of the book:
http://www.grassbook.org/errata_menu3rd.php
Here is what I did
g.region rast=el_D792_6m -p
v.extract P079215 out=bldg_resid_a where="layer='BLDG_RESID_BL'"
v.extract P079215 out=bldg_cmcl_a where="layer='BLDG_COMMER_BL'"
Here the step to change the vector type was omitted in the book example.
v.info bldg_resid_a -t
nodes=14
points=0
lines=11
boundaries=0
centroids=0
areas=0
islands=0
faces=0
kernels=0
primitives=11
map3d=1
--> no boundaries but lines only.
So you need to perform here:
v.type bldg_resid_a out=bldg_resid_bnd type=line,boundary
v.centroids bldg_resid_bnd out=bldg_resid_pol
v.type bldg_cmcl_a out=bldg_cmcl_bnd type=line,boundary
v.centroids bldg_cmcl_bnd out=bldg_cmcl_pol
# add height of the building (use new input maps)
v.extrude -t bldg_resid_pol out=bldg_resid_a_3d height=10 \
elev=el_D792_6m
v.extrude -t bldg_cmcl_pol out=bldg_cmcl_a_3d height=15 \
elev=el_D792_6m
# verify
v.info -t bldg_resid_a_3d | grep faces
faces=36
v.info -t bldg_cmcl_a_3d | grep faces
faces=55
g.region rural_1m -p
nviz elev_lid792_1m col=ortho_2001_t792_1m vect=bldg_resid_a_3d,bldg_cmcl_a_3dI've encountered also this problem when I tried to visualised a DXF file in NVIZ. The windmill shows up but in broken lines which is no good to me.
... now you see the buildings nicely.
> Thank you for your help, I'm very new to GIS and Open Source,
and I must admit I don't know where to find the ressources to help...
It will be the same problem with solution to be applied from above.
Hope this helps,
Markus
http://www.grassbook.org/neteler/
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20110825/47168c71/attachment-0001.html
