[GRASS-dev] Re: [GRASS GIS] #1426: v.colors resetting vector display
trac at osgeo.org
Thu Aug 25 13:08:50 EDT 2011
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: v.colors | Platform: Unspecified
Cpu: Unspecified |
Comment(by cmbarton):
Maybe it's happing if v.colors is run with rules=
This effect can be seen when setting color rules via colorrules.py
OnApply calls v.colors rules=[some rules], and then UpdateMap. When it
does, it resets all d.vect settings back to default except for the color.
If it is not v.colors. It is not UpdateMap that is causing this. The only
other command being run is v.colors rules=
Ticket URL: <http://trac.osgeo.org/grass/ticket/1426#comment:6>
