[GRASS-dev] Re: [GRASS GIS] #1426: v.colors resetting vector display
trac at osgeo.org
Fri Aug 26 14:36:08 EDT 2011
Reporter: cmbarton | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: v.colors | Platform: Unspecified
Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:11 cmbarton]:
> I'll test the revision. Thanks. It seems like something in v.colors was
running d.vect -a and it shouldn't do that. It should simply set the
colors.
`v.colors` cannot run `d.vect` itself, it' just modifying color table.
wxGUI wrapper runs `d.vect` for preview. Also note that `d.vect -a` is
required only for color rules stored in attribute table. If you set up
file-based color table, `d.vect` renders vector table colorized without
any flag.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1426#comment:12>
