[GRASS-dev] Location EPSG code storage
Pawel Netzel
pawel.netzel at uni.wroc.pl
Tue Aug 30 02:39:44 EDT 2011
----- "Maris Nartiss" <maris.gis at gmail.com> napisał:
> Options:
> a) add a new key-value pair to PROJ_INFO
> + all information is stored in single place
> + projection information reading/writing code is already inplace
> - it needs to be changed to deal with a new key-value pair
> - breaks backwards compatibility
> - EPSG code might not be known for most of (existing) locations
Yes (with code "epsg not known" for locations without epsg)
This solution does not create a new file.
All projection parameters are in one file.
Regards
Pawel
