[GRASS-dev] where to store GRASS settings: GISRC and wx settings
Michael Barton michael.barton at asu.edu
Wed Aug 31 12:29:33 EDT 2011
I WAS using it a lot, but use 6.4 and 7 more now, and we are using it in our modeling work. But this is because it was supposed to be the roadmap to GRASS 6.4.2 and we wanted to make sure that all of our modeling worked with the final GRASS 6.x series. 6.5 has diverged from this to some extent, though most of its code is in 6.4.2. So it won't be a problem to me or my lab if it goes away.
Michael
______________________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671(SHESC), 480-727-0709 (CSDC)
www: 	http://csdc.asu.edu, http://shesc.asu.edu
		http://www.public.asu.edu/~cmbarton
On Aug 31, 2011, at 11:23 AM, grass-dev-request at lists.osgeo.org wrote:
> Date: Wed, 31 Aug 2011 09:12:38 +0200
> From: Markus Neteler <neteler at osgeo.org>
> Subject: Re: [GRASS-dev] where to store GRASS settings: GISRC and wx
>        settings
> To: Markus Metz <markus.metz.giswork at googlemail.com>
> Cc: GRASS developers list <grass-dev at lists.osgeo.org>
> Message-ID:
>        <CALFmHhsdRqiT_ndtGJWmg-TDrhhy8aTcGYEp2u17_xbNMDbQFA at mail.gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> On Wed, Aug 31, 2011 at 9:02 AM, Markus Metz
> <markus.metz.giswork at googlemail.com> wrote:
>> Glynn Clements wrote:
>>> Personally, I'd just kill the 6.5 branch. If something is too major to
>>> go into 6.4.x, it should be reserved for 7.0.
>> +1
> I am also not quite sure about the need of the 6.5 branch?
> For me it is sufficient to have 6.4 as production system and 7 as
> experimental system.
> Honestly, who's *using* it as a user?
> Because: yes, it can (could?) be branch to be used for testing but
> I actually don't know anyone who really uses 6.5 for work.
> Please tell us if you use 6.5 for work to understand if this branch is
> really needed.
> Markus
