[GRASS-dev] Re: [GRASS GIS] #1501: g.extension fails when addons
directory doesn't exists
trac at osgeo.org
Thu Dec 1 01:22:07 EST 2011
#1501: g.extension fails when addons directory doesn't exists
Reporter: martinl | Owner: hamish
Type: defect | Status: assigned
Priority: major | Milestone: 6.5.0
Component: Default | Version: svn-develbranch6
Keywords: g.extension | Platform: Unspecified
Cpu: Unspecified |
Comment(by hamish):
fixed in r49451,2.
fwiw i.points.auto is an awkward test for it as it doesn't use the
standard parser. (one of a number of i.points improvements to be back-
ported; i.points.auto is based on a 2004 copy of i.points)
with an empty (or non-existent) addons dir could you try editing line 412
of grass 6.5's g.extension to be `[ 0 -eq 1 ]` and installing a few addon
modules? After seeing it I hope you agree it is a much cleaner way to
organize things. If there is a technical reason not to clean that up I'd
still like to hear what it is, as I know of none.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1501#comment:2>
