[GRASS-dev] Re: [GRASS GIS] #1358: WinGRASS 6.4.1: SQLite driver
errors: `Unable to open database'
trac at osgeo.org
Thu Dec 1 01:36:16 EST 2011
#1358: WinGRASS 6.4.1: SQLite driver errors: `Unable to open database'
Reporter: rvanderweide | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.2
Component: Database | Version: 6.4.1 RCs
Keywords: wingrass, SQLite driver | Platform: MSWindows 7
Cpu: x86-64 |
Comment(by hamish):
Replying to [comment:3 mmetz]:
> This is most probably a SQLite problem because the database is
> in the same folder like the shapefile to be imported. Files in
> this folder are opened by OGR, after that sqlite tries to create
> a new database in that folder but does not have exclusive rights
> on that folder because other files in that folder are opened.
so does OGR hold open ''all'' files in the dir, even unrelated filenames
to the shapefile layer? how about same layer name but .sqlite or .db
extension? (ie unknown to the shapefile format)
I would not think that you could fopen() a dir in Windows, holding the
rest of the dir hostage.
can anyone reproduce this?
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1358#comment:5>
