[GRASS-dev] Re: [GRASS-SVN] r49437 - grass/trunk/gui/wxpython
Glynn Clements
glynn at gclements.plus.com
Thu Dec 1 03:50:42 EST 2011
Martin Landa wrote:
> > building grass 7 with `make -j 8` on a muti-cpu machine ends with a
> > build error in the wxpython docs dir. `cd gui/wxpython/` and running
> > `make` has no error, so I suspect it is just a Makefile dependency thing.
> http://lists.osgeo.org/pipermail/grass-dev/2011-November/056482.html
> Still not solved.
Try r49455.
