[GRASS-dev] GRASS 7: replace r.los with r.viewshed?
Markus Metz
markus.metz.giswork at googlemail.com
Fri Dec 2 03:20:52 EST 2011
Hamish wrote:
> Markus Neteler wrote:
>> how about replacing r.los with r.viewshed?
> needs fixing:
> grass65/dist.i686-pc-linux-gnu/include/grass/iostream/replacementHeapBlock.h:146: warning: 'str' may be used uninitialized in this function
> (3 times).
Did you ever have a look at the compiler warnings for r.terraflow?
I have already ported r.viewshed to trunk in my local copy, I just
need to submit it...
Markus M
