[GRASS-dev] wxGUI: new packages layout
Martin Landa
landa.martin at gmail.com
Fri Dec 2 07:37:46 EST 2011
2011/12/2 Maris Nartiss <maris.gis at gmail.com>:
> No. Pure CLI (Konsole). Modules, that fail to start, g.copy, g.rename,
> g.remove, g.region (others too?). g.mapset, g.filename work fine. Had
> no time to test all modules. r.* v.* and d.* modules seem to work just
> fine.
they don't fail to start, the modules which has no required options
(such g.remove) just do nothing. This is a feature of the parser in
GRASS 7, this behaviour seems to be quite confusing for the user.
To force GUI dialog run
g.remove --ui
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
