[GRASS-dev] parallelizing GRASS modules
Hamish hamish_b at yahoo.com
Sat Dec 3 18:00:49 EST 2011
Seth wrote:
> If you decide to use opencl, keep in contact and I
> might be able to help. I'm traveling for at least
> the next few days, though.
I plan to work on adding OpenCL support to the build
system soon after the OpenMP support is done.
the last missing piece for the OpenMP stuff is to
add a test compile to configure.in which does
  $(CC) $(OMPCFLAGS)
to check if the named compiler really has OpenMP
support built in.  (e.g. for gcc test if `gcc -fopenmp`
works, as that only exists for gcc versions >=
4.2.1)
it should be trivial but I'm no autoconf expert.
I see that Autoconf has a AC_OPENMP macro, but don't
know if that applies to version 2.13. I'm guessing
that it doesn't.
http://www.gnu.org/software/autoconf/manual/html_node/Generic-Compiler-Characteristics.html#Generic-Compiler-Characteristics
Hamish
