[GRASS-dev] compiling error addon r.stream.pos - grass65svn
(ubuntu 11.10)
Markus Neteler
neteler at osgeo.org
Sun Dec 4 08:47:37 EST 2011
On Sun, Dec 4, 2011 at 11:17 AM, Helmut Kudrnovsky <hellik at web.de> wrote:
> hi
> tested with grass65svn (r49498) in a ubuntu 11.10-32bit-box
> (AFAIR two weeks or so ago, there wasn't following error):
> _________________________________________________________
> GRASS GIS compilation log
> Started compilation: Sa 3. Dez 19:56:23 CET 2011
> Errors in:
> /usr/local/src/grass6stream/raster/r.stream.pos
> myricaria at myricaria-hp-pavilion-ze4900-PJ920EA-ABD:/usr/local/src/grass6stream/raster/r.stream.pos$
> make
> ../../include/Make/Module.make:25: Warnung: Die Befehle für das Ziel
> »install« werden überschrieben
> ../../include/Make/Rules.make:90: Warnung: Alte Befehle für das Ziel
> »install« werden ignoriert
> gcc -I/usr/local/src/grass6stream/dist.i686-pc-linux-gnu/include -g -O2
> -DPACKAGE=\""grassmods"\"
> -I/usr/local/src/grass6stream/dist.i686-pc-linux-gnu/include -o
> OBJ.i686-pc-linux-gnu/io.o -c io.c
> In file included from
> /usr/local/src/grass6stream/dist.i686-pc-linux-gnu/include/grass/vect/digit.h:3:0,
> from
> /usr/local/src/grass6stream/dist.i686-pc-linux-gnu/include/grass/Vect.h:4,
> from global.h:7,
> from io.c:2:
> /usr/local/src/grass6stream/dist.i686-pc-linux-gnu/include/grass/vect/dig_structs.h:26:21:
> schwerwiegender Fehler: ogr_api.h: file or folder couldn't be found
> Kompilierung beendet.
> make: *** [OBJ.i686-pc-linux-gnu/io.o] Fehler 1
> _____________________________________________________________
> usr/include/gdal/ogr_api.h is here
> any ideas?
Here an older, similar posting with i.pr:
On Fri, Jan 29, 2010 at 2:34 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Luisa Peña wrote:
>> /usr/local/grass-6.4.0svn/include/grass/vect/dig_structs.h:22:21: error:
>> ogr_api.h: No such file or directory
> Where are the GDAL/OGR headers installed? "gdal-config --cflags"
> should provide a clue.
> I suspect that i.pr_*/Makefile need:
> EXTRA_CFLAGS = $(VECT_CFLAGS) -I$(PRINCLUDE)
> The vector headers include the OGR headers, so anything which includes
> the vector headers needs any -I switches which are required to find
> the OGR headers.
Could you try this?
Markus
